vcWorldManager
vcSimWorldManager provides access to different worlds used in the application.
Referenced by: vcApplication.WorldManager
ActiveWorldvcWorldRGets the current vcWorld to which all UI and API actions should be directed to.
The value is never None nor invalid because StaticSimWorld is used as a fallback value."
StaticDrawingWorldvcWorldRGets the main 2D drawing world. This instance is static meaning it is never deleted or replaced.
StaticSimWorldvcWorldRGets the main simulation world. This instance is static meaning it is never deleted or replaced.
NameParametersDescription
OnActiveWorldChangedvcWorld worldEvent triggered when the ActiveWorld property value has changed.
world (vcWorld): The now active world.
